Philco 3010 Audio Output Transformer
So I am new to the radio hobby. Recently I have gotten a model 3010 that has a bad audio output transformer. What kind of new transformer can I use to replace the original? Thanks for the help!
Nathan
Hi Nathan and Welcome to the Phorum
I'm unfamiliar with that model would it be a tube type set??
Nathan,
if you have the sch then give the link or scan it and attach.
At least give us an idea what tubes it uses in the output, whether it os a push-pull or a Class A (SE) etc.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
There are currently 3619 online users. [Complete List]
» 1 Member(s) | 3618 Guest(s)
