Display of Philco Radios
I was browsing around the Library of Congress web site and came across this photo,
[Image: https://www.dropbox.com/s/bcmz7j12mdazxb....jpg?raw=1]
You can download a high res image if you like. Not much other info on the photo, just kind of neat.
That is cool!
I am not sure when exactly, but pretty recently, maybe in the spring, someone posted a simiar one here and we even discussed the giant radio in it.
I remember that post...and you can see the giant radio on one of Ron's Philco history pages.
I've noticed Shorpy suffers from a dearth of Philcos. Do a search for Philco on Shorpy and you get a small handful of hits. I like this one, though, of a large array of Philco batteries that seem to be powering a PA system in the 20s. Another good one in the Philco list at Shorpy is a store front sign for the "Philadelphia Diamond Grid Battery." http://www.shorpy.com/node/17169
Cool picture of back in the day...Hmmm, why cant we go back to that era when things were less stressful on family were always together?
There are currently 9607 online users. [Complete List]
» 1 Member(s) | 9606 Guest(s)
