Philco 60 cabinet variations
I have 4 Philco 60's and 3 different cabinet styles. Do they have different numbers for the cabinets?
cabinet 1 is the one I am familiar with.
This one I am not:
And this one:
Thanks
Kirk
You also have that with concentric semi - circles. Also used in 60. And mine.
http://www.philcoradio.com/tech/60evol.htm
Yeah I saw that so I guess they are only different by year, not model #
Thanks
Kirk
There are currently 6603 online users. [Complete List]
» 1 Member(s) | 6602 Guest(s)
