Does anyone have a 48-1262 that they could snap a picture of the back high lighting the loop antenna? I have one that is missing the antenna and would like to see what an original looked like.
Thanks for your help!Icon_thumbup
Gregb
There are currently 4441 online users. [Complete List]
» 4 Member(s) | 4437 Guest(s)
AvatarAvatarAvatarAvatar
