Philco 60B Decal Size/Position
I have a late model 60B cathedral (doesn't have the shield base around the 6A7, so it was one of the last runs I believe) that someone refinished, but didn't put the sole Philco logo decal on.
I want to put it on, but it looks like RD offers them in several sizes. Does anyone know what the correct size is? And I'm assuming it's centered horizontally. Is it also centered vertically between the tuning and band switch knobs, or offset one way or the other?
Thanks!
Edit: Oops, probably should have put this in the refinishing forum. The electronic one is usually the one I'm in. If a mod could please move this, I'd appreciate it.
This is what you want to use on any 1932 to 1936 Philco:
http://www.radiodaze.com/product/6049.aspx
DCL-PH8. Some early 1937 Philco models used this style decal as well.
And I moved this thread to Philco Cabinet Restoration as well.
There are currently 5373 online users. [Complete List]
» 3 Member(s) | 5370 Guest(s)
