Philco chassis fit
Does anyone know if a model 60 philco chassis will fit into a model 620 tombstone cabinet? Thank you
The thankful receiver bears a plentiful harvest.
 Why not just get a model 620 chassis and speaker for the 620 cabinet? The model 60 could possibly be made to fit but it will always look like a hack job, for one thing the dial is smaller.
Yes, the dial of a 60 is much smaller than the 620 dial. Besides, I'm not sure that the tuning shaft would fit properly. I no longer own a 60 or 620 so I can't measure.
620 chassis are not hard to find. Better yet, get a 630 chassis, remove its shadowmeter and bypass it with a 1000 ohm resistor. The 630 runs a higher B+ so it produces another watt or two of audio output.
I had a 630B with a rough cabinet, and an empty 610T "Big Bullet" cabinet. I now have a hybrid 610T with 630 chassis. Icon_smile
Speaking of 620B and 630B cabinets, if anyone has an empty one they want to part with, I may be interested, I think that the 623 battery set used the same. I have one that someone gave me a s a gift year ago, and whilst the radio works well someone went at the cabinet with a sander. The friend who gave it to me tried to fix it up, most of the damage is covered by a dark stain, but the pilaster moldings on the front were ground down pretty badly. I could probably repair it if I had replacement moldings, but it's probably easier to find an empty cabinet. Then again I could do what Ron did and find an empty bullet cabinet.
Philco 91 Restore Code ??
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
There are currently 2191 online users. [Complete List]
» 4 Member(s) | 2187 Guest(s)
AvatarAvatarAvatarAvatar
