Why did Philco have 2 screws , marked red & black, on a rear of model 116B ?
Threads: 9
City: Joliet,IL.
Hello out their,
I was going to add a audio input jack to a Philco #116B, but I noticed a (2) two screw terminal strip in the rear of the chassis, marked Red & Black ! Might that be for a phono-input , that I can use for my audio input , or were they put their for another reason ? Currently their are NO connections, between them !
Thanks for your help, Lee Petrie, Joliet, IL
Threads: 563
If it is anything like in 37-116, it is not for Phono (well, it is not in your case certainly), in mine they are for some form of loop antenna.
Threads: 9
City: Joliet,IL.
(11-28-2014, 09:32 PM)morzh Wrote: If it is anything like in 37-116, it is not for Phono (well, it is not in your case certainly), in mine they are for some form of loop antenna. Thanks for your quick reply, Morzh, I tried to attach the audio from a CD player to the red & black screw lugs , appears to be NO input from that connection ! I guess I'll do it the old way , on the feed TO the volume control, that I have done before ! Thanks again , Lee Petrie, Joliet, IL. ( 35 miles SW of Chicago )
The RED and BLK screws are for Philco's All Wave Aerial, later called the Philco High Efficiency Aerial. It was a dipole with two twisted leads used as a lead-in. The red wire connected to the RED screw; the black wire to the BLK screw.
A little more info here:
http://www.philcorepairbench.com/mystery/40-6112.htm
If the set owner did not use the special Philco dipole, he or she could connect a conventional longwire to the ANT fahnestock clip on the chassis.
If there are no connections to these screw terminals inside the chassis, then someone has monkeyed with the set at some time.
Threads: 9
City: Joliet,IL.
(11-28-2014, 10:31 PM)Ron Ramirez Wrote: The RED and BLK screws are for Philco's All Wave Aerial, later called the Philco High Efficiency Aerial. It was a dipole with two twisted leads used as a lead-in. The red wire connected to the RED screw; the black wire to the BLK screw.
Hi Ron,
Thanks for the input, It didn't look like a phono input , but I thought I would ask anyway ! I guess I "miss spoke" , I meant to say , their are no wires attached on the outside of the chassis , but inside the chassis their are 2 wires that run to the last "selector switch wafer" , looks like original wiring !
Thanks again for your help, Ron, Lee Petrie, Joliet, IL.
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
