Philco ID
Ok guys, which model is this?  Saw this at another collector's stash yesterday. Is the grille cloth authentic?  Looks like a 112X to me.
Mike (morzh) recently made a similar post about the same model Philco. I shall give you the same answer:
In the words of ol' Harry...
It might be...
It could be...
IT IS!!!
[Image: http://i326.photobucket.com/albums/k420/...f~original]
http://www.philcoradio.com/gallery/1932a.htm#e
No, the cloth in the set in your photo is not original.
I didn't think so.
There are currently 10180 online users. [Complete List]
» 1 Member(s) | 10179 Guest(s)
