This radio doesn't know the words!
Threads: 113
City: The Villages
Because at low volume it hums ![Icon_crazy Icon_crazy](https://philcoradio.com/phorum/images/smilies/icon_crazy.gif)
The latest subject is a DeWald C-800 . With the volume turned all the way down, I have a steady hum. It doesn't get any louder when the volume is turned up. It just hangs back in the background when tuned into a station.
All caps replaced (except micas). Resistors checked and replaced as necessary. All tubes tested ok. Alignment done. On both AM and FM stations come in loud and clear.
Any ideas? This has really got me . I may take a ride over to freezing lake Michigan and jump in-like someone else we know
Eric
The Villages, FL
Threads: 563
Eric
There have been several threads lately addressing the similar problem.
All I can tell you:
1. Check all tubes for shorted Filament and Cathode (uually output ad Det/1st Audio)
2. Bad grounding - rivets etc
3. Shorted Gnd to chassis if separate, or shorted Filament wire to chassis.
4. Mechanical noise from the power transformer
You have to poke around.
Like, pull tubes one by one, see if it stops and with what tube. Then go from there.
Threads: 268
Agree with Mike but when you start pulling tubes leave the rectifier in. If you pull it you will loose all HV Also replace the tube back into it's socket before going to the next one. You don't want to have with just the rectifier tube in it at the end of testing.
Threads: 563
Yep, that's the point - one at a time while having the HV, we need to know which one it stops at.
Threads: 113
City: The Villages
Thanks for the ideas, guys. I don't think that I should pull tubes because it has no power transformer. I have swapped out each tube one by one with no change. I'll check grounds. Anything else you can think of for this AC/DC beauty?
Eric
The Villages, FL
Threads: 563
Threads: 113
City: The Villages
Nope. has polarized plug - common to ground.
Eric
The Villages, FL
Threads: 18
Don't bet your life or your reception on wall socket being wired correctly. Try in another room where a similar set works OK.
Threads: 563
Although I try to wire chassis following Wide-Neutral convention. I would never rely on it for safety. For exactly the same reason - it cannot be guaranteed.
Threads: 54
I would loose the polarized plug, at least temporarily, I see that this is an AM/FM set so I would go back to how the factory had it wired until you can rule that out. Some AC/DC sets do not like having the neutral and hot side swapped on the power switch since it's often on the back of the volume control, I also noticed that the FM and AM detector tubes have their heaters connected closest to common negative/AC Neutral at the end of the filament string. If it is not being caused by this, or a heater to cathode short, then there must be an open ground connection, or something incorrectly wired.
Thank you for your replies.
That is the correct schematic and pin out diagram for the rectifier. The resistance acro...bluecap — 11:01 AM |
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
There are currently 3928 online users. [Complete List] » 4 Member(s) | 3924 Guest(s)
