Chassis rust
Hello,
I was curious what you guys usually do to remove light rust from the chassis. In the past I have used M.E.K, steel wool, acetone, and some other crazy things. I am looking for something better and easier. Any info or suggestions would be appreciated. Thanks.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8182 online users. [Complete List]
» 1 Member(s) | 8181 Guest(s)
