Radiobar decal
All, I've got a Radiobar 107 with an unusual decal.  It's almost identical to the decal sold by radiodaze except it has the word "with" inserted between the words Radiobar and Philco.  Has anyone else seen one with this decal.  At one time they were advertised as "Radiobar with Philco" so I'm not surprised to see it on the decal.
Here's a closeup radiobar decal
Keith
John at Radiodaze now has the "Radiobar WITH Philco" decal http://www.radiodaze.com/philco-radiobar...-ph-bar-w/
Keith
