40-155 Antenna loading coil
I'm in the process of trying to save a Philco 40-155 which previously served as a "mouse house"....see photo...
Besides a lot of chewed up wiring, caps, resistors, etc. the Antenna Loading Coil  (5A) has been destroyed--wiring chewed up.
Can someone suggest a "work around" for this?
Mark
There are currently 9121 online users. [Complete List]
» 2 Member(s) | 9119 Guest(s)
