Do you know this part?
I began my first-ever restoration -- a 37-610 code 125. And when I removed the chassis from the cabinet, this piece was jammed underneath. It appears to be plastic so I don't think it comes from the radio, but I just don't know. I think it's plastic because it appears to have melted beneath the chassis. I don't think bakelite ever gets misshapen like this, does it? This radio did have signs of having been repaired once in the past. The power cord was replaced with a modern cord. One of the rubber bushings that the chassis sits on inside the cabinet is missing and it appears this piece was jammed in there to keep the chassis from shifting. But all of this is mere speculation. I am a total novice at this. So anyone know what this is? My only concern is that it could come from the radio somehow.
[Image: http://www.jamesdavidporter.com/photo%201.JPG]
[Image: http://www.jamesdavidporter.com/photo%202.JPG]
Thanks!
Hi Jim
No worries. That does not look like any Philco part I have ever seen. I think you're right, it's something someone just stuck in there for some reason.
Welcome to the Phorum Jim!
Was about to say the same, does not belong there, pobably got there by accident.
Dick Tracy left it behind.
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 3291 online users. [Complete List]
» 4 Member(s) | 3287 Guest(s)
AvatarAvatarAvatarAvatar
