Volume control for Philco 65
Where is this in the schematic/circuit? I'm looking at the schematic trying to find it so I can try to help someone out with a problem (volume control is running hot?), but I don't even see a volume control in the schematic at all.
http://www.nostalgiaair.org/PagesByModel...013823.pdf
Has to be the item that is labelled #1 (listed as 10,000 ohms on the first page) doesn't it??  Just drawn funny, as though the wiper is at the high ohm end of the pot?
http://www.philcoradio.com/tech/images/65.jpg
Part (25), 1,750 ohms. It controls the screen grid voltage of the two 224 RF amps.
ooops... Icon_redface
thanks Ron!
Thanks. I did find it after I posted this.. it's just in a very odd spot on the schematic so I didn't find it right away.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1231 online users. [Complete List]
» 1 Member(s) | 1230 Guest(s)
