Silvertone 1720 Information
#31
(04-24-2015, 09:55 AM)OldRestorer Wrote:  4 45 output tubes!
Well if they are globes you hit a home run!
The tubes alone sell for $100+ each.
Non globes can go for $50.00 each so you made back your money right there.
Love to see some pics if you can get front and back
Kirk
 New old stock and in the box, maybe, used and pulled from a radio, absolutely not!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
