42-1008P ALigntment
Yup, I agree.. Were you able to get rid of the signals appearing on 2 frequencies by changing out the caps?
Skip...
I changed one that didn't appear to be off as much as I thought and it didn't change anything.
I think the signals were just images and being so close to the generator.
I did not hear WWV on multiple dial settings however it really wasn't coming in very strong.
OK, That's good. Glad its coming along.. If you need any more help.. Please lets us know..
Skip...
