Restored Airline 62-101
Just finished this airline that I got at Sargents auction 2 weeks ago. Looks great. This radio cabinet needed a lot of work. Both sides were replaced including plywood inners and veneer, top veneer and cabinet has been reglued and ball feet  were reglued , inside cabinet has been painted and new speaker board . Solid as a rock, still looking for 1 nob. Recapped and cleaned , plays good.
It looks just grand.
Love it very sharp looking. really like the dial .where the knob
Sam
As usual, very nice!  Icon_thumbup Icon_thumbup Icon_thumbup
M R Radios   C M Tubes
What a beautiful radio ! I would love to see a picture of it in low light and working, so I could see the dial glowing in that beautiful setting.
Wow, great job!
Crist
Fred, you just do terrific work! That is just a lovely radio.
Jerry
Im still looking for one nob for final touch. Got it home today and took more pictures with it playing.
That is absolutely beautiful ! Thanks for the pictures!
Fred....Looking great as always thank you for posting your beautiful radio!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
