Delco Model 60108
Wanted to share with you guys my newest Adoption. It is supposed to work, it was rebuilt about 15 years ago but I am not going to try it until I check out the chassis, can't say I trust the person who rebuilt it. Thought you guys would be interested in seeing it. Anyone know anything about this radio? Thanks..
[Image: http://i1348.photobucket.com/albums/p721...7oenh1.jpg]
[Image: http://i1348.photobucket.com/albums/p721...srmttj.jpg]
I know that the back isn't standard issue.
looks nice to me  Icon_thumbup Icon_thumbup
but why the inlay near top ?
also looks like an arrow head in grill pointing to dial ? shadow?
back cover really needs to go Icon_thumbdown
sam
Not shadow, I think it is intentional
The inlay your talking about is at the top of the grill where the speaker cutout is? There is one at the bottom also. Thought it was made that way. yea looking at the back it is an add on by someone isnt it.
I have to 6V version. With it's vibrator power supply it only draws 9W.
Very Nice... it seems on yours it is darker around the edges but mine seems to be close to the same shade all over. Phlogiston, or anyone else for that matter, do you know where I can get a schematic for this radio? Thx for any help.
Look for the schematic on Nostalgia Air under United Moters Service - Delco.
http://www.nostalgiaair.org/Resources/
Are you sure of that model number?
Before and after refinishing picture of mine:
I added the shading to match the original finish.
(06-16-2015, 10:31 AM)Phlogiston Wrote:  Look for the schematic on Nostalgia Air under United Moters Service - Delco.
OK, I will look on nostalgiair. No, not 100% sure of the model number, that is what someone wrote on the back of the radio. Your radio looks real nice. I thought mine was the original finish, doesnt look like anyone has done anything to the cabinet, but like i say the edges arent really darker than the front like yours. Looks nice with the darker edges.
That back will make it a toaster, plus the holes are at the bottom of the cover.
Nice looking sets
It might be the original finish. They weren't necessarily all the same or finished at the same time by the same guys.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
