I need a good flocking..
    I have 3 record platters from 1950's Philcos that I need to reflock.  They were flocked originally by applying an electro static charge to the record platter - which produces a nice even and fluffy surface.  I can't find anyone who does this anymore online.   There is a company that makes an electrostatic flocking applicator device - costs about $120.00.  I wonder if any of you have tried this?  Company claims the high voltage charge follows the flocking fibers onto the surface you are flocking - wondering if this works well and will reproduce the nice even, soft surface found on these record platters from the 1950's.
https://www.craftflocking.com/shopping/p...d=258&=SID
[attachment=7621]
Hi OD.....
I THINK West Tech may still be doing the flocking on platters. Gib seems to be winding the business down but I knew his wife was doing the flocking and had always been doing it. Give them a call.
Flocking platters depends on how well the surface has been prepared. I've done it before and the results were good but practice makes better. Getting the old crud off can prove a challenge however power washing it seemed the best method. For adhesive I used 3M Super 77 spray glue with a brand new spray head attached. It comes with 3 types of heads...use the fine mist one. I bought fine flocking from Michaels Art store supply. Using a pan larger than the platter, spread an even pile of the flocking on the pan. Coat the platter evenly with the glue and let it set for about 5 minutes.  Remember to coat the platter skirt with glue as well.
While not touching the glued areas, hold the platter upside down and as evenly as possible come straight down onto the flocking...now press hard, then lift and turn right side up.
The second part will require a spindle to pass through the hole. The spindle will allow you to roll the edge of the platter into the flocking to get the edge done. Again, press hard while doing this.
Allow to set and dry for at least 2 hours.
Carefully blow off the excess flocking.
Good luck with your endeavour.....
...Jim
Thanks Jim - I did contact West Tech - they no longer do it. I think I will just try it with your method - but maybe I'll practice on some scrap metal first. Thanks for your detailed explanation on flocking.
Best regards,
Mike
(07-06-2015, 10:40 AM)Jim Koehler Wrote:  Hi OD.....
...Jim
There are currently 4983 online users. [Complete List]
» 1 Member(s) | 4982 Guest(s)
