Can you tell me about these caps?
    I'm working on an RCA 28X and have a few of these caps that I haven't seen before. I think they are 150 pica.
Are they paper? Should they be replaced? What are they called?
Thanks.
Don't think they are paper should be 500v micas. You could check it with a cap meter. Or leave it in and see if the alignment is ok. Or you could replace if you like.
As Terry said, leave them be, see if the alignment is good. If yes (likely), keep them.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3276 online users. [Complete List]
» 1 Member(s) | 3275 Guest(s)
