edison juke box
this is so cool
way out of my range though Icon_cry
http://www.ebay.com/itm/ANTIQUE-JUKEBOX-...3f529d79e9
click on bottom of page to see working
sam
I remember seeing that auction a year or two ago. That is pretty cool, very expensive, but very cool and at 7 feet tall it is also bigger than than I expected.
 WOW! Never knew there was any type of juke box that early. Very beautiful. Wonder what the reserve amount is.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7198 online users. [Complete List]
» 1 Member(s) | 7197 Guest(s)
