GE J64 back
Working on a General Electric GE J64 radio circa 1941.  http://www.nostalgiaair.org/Resources/104/M0008104.htm
Anyway it once had a back because there are screw holes,  anyone have a picture?
I just finished one, and the back was missing on mine as well. I made a new one based on a picture on radiomuseum.org. I can take a pic of mine if you want, but the one on rm.org is pretty good.
These are nice sets, good luck with yours.
Thanks, got it! Learn something new every day (still!)
Happy to help out Icon_smile
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
