I have been lucky!!
In the last couple of days I have come up with 2 great finds. Has anyone In their radio collection come across a Westinghouse 370 console radio that was made in the run of 1939? The one I came across is in very good condtion. The chassics shows a little bit of rust though. If anyone has heard of this set or has one in their collection please let me know. I have not heard any talk on this console on this porum....I would like to know more about this console before I add it to my collection. THANKS!    Icon_confused
Hi John,
Looks like a real beast! RF amp,separate osc/mixer toobs, two IF stages, 10 wt p/p output, 12'' spkr and motor tuning. Hope it doesn't have rubber wire.
It is called The Philco Phorum after all.
Do you have some pictures of the radio in question?
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
