1950 Admiral Model 6S12
(02-05-2016, 02:38 PM)Eliot Ness Wrote:  Dickel did a good job polishing your cabinet, but his run for prez will get derailed when they look in his closet and find all those skeletons Icon_wink
Nice job on that volume control Buzz!  Is Evapo-Rust non-toxic?  Is that one benefit over Naval Jelly?
I think evaop=rust is non toxic...its ok if you have lots of time, but to do the job quick naval jelly works..watch in my next video..
Part 6 now uploaded to anyone interested
https://www.youtube.com/watch?v=luWZyTZfV4M
Icon_thumbup
Better than Saturday morning cartoons!
Part 7 and final episode now uploaded..
Link below to anyone interested
https://www.youtube.com/watch?v=mQ9CF-96Ajo
Nice work Buzz Icon_thumbup
(02-21-2016, 08:05 PM)Eliot Ness Wrote:  Nice work Buzz Icon_thumbup
thanks for you support Eliot...Buzz
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
