Philco 611T Finish
I have a 611T that has been poorly refinished and am wondering what the proper color is. I looked at the pictures on Rons site and the 610 and 611 are very light, are they refinished or is that correct? I would like to do a proper refinish on mine and would like to get the color correct, lets hear your what your thoughts are.
Thanks
Gregb
Pictures
Me
The 611T should, I think, look like a 610T. Medium Walnut overall with a heavy coat of Perfect Brown on the bottom trim, or a light coat of Extra Dark Walnut on the bottom trim.
http://philcoradio.com/gallery/1936b.htm#i
Thanks Ron, I will go with your recommendations.
Gregb
