40-190 Finish
Lets see how you finished yours.
I'm hesitating a bit trying to figure out how I want to attempt this Icon_neutral
Well, this is one of the radio I have owned the longest, at least 35 years.
So the first time was wrong:
No picture
The second time looked cool but wrong - very wrong.
The third time was better:
Mine originally looked like the one at the link below w/ the dark fading at the top sides and dark lines on the edges.
I was going to Sharpie in the lines like I did on a 41-280. Still thinking about that though.
[Image: http://www.philcoradio.com/gallery/images/trans.gif]
http://www.philcoradio.com/gallery/1940a.htm#ae
This is my 40-190 and was not refinished like philco intended but the way I intended. I kinda jazzed it up a bit .Icon_think Icon_think
