can a 41-280 escutcheon go into a 42-380 cabinet?
Threads: 1
City: Albany, California
Have a battered 41-280, someone parked it in a shed for 30 years and the sides warped. Would like to salvage the faceplate, buttons, glass, etc. but perhaps have them put into a 42-380 body that's in better shape. Is this even remotely feasible? And if so, how would I clean up the buttons?
Thanks!
Hi Debra,
Yes - if you remove everything from the 41-280 cabinet, it should all fit in the 42-380 cabinet.
You can't use a 42-380 escutcheon with a 41-280 chassis and vice versa, though, because the 41-280 has 8 pushbuttons and the 42-380 has 9.
Bob has alrady given you some good advice on cleaning the knobs and pushbuttons here.
Threads: 1
(04-26-2016, 06:07 AM)Ron Ramirez Wrote: Hi Debra,
Thanks for the info on switching out chassis, and also Bob's info on the buttons. I've worked on the buttons and they improved, but do show considerable wear. Will have to get "new" ones from http://www.renovatedradios.com/parts.html. Do you know if there is more than one type for the 1941 consoles (41-280 and/or 42-380), that is, long, short, etc.???
Also re the band below the buttons, is that copper? I saw the advice about not using Brasso on it....
Thanks!!
~Debra
Threads: 12
City: Nashville, TN
(04-27-2016, 05:44 PM)debra Wrote: Also re the band below the buttons, is that copper? I saw the advice about not using Brasso on it....
Thanks!!
~Debra
Hi Debra. The metal strip is brass I believe. If you use Brasso, i will remove a clear coating and get down to the actual metal. That also may remove the lettering. ( I forget if the lettering is flush with the strip, or if it is lower.) In other words filled with a paint. If your strip is very badly tarnished, no amount of polishing that clear surface will get rid of it.
Also if the lettering is not indented below the surface, you'd have to apply decals or lettering to replace it.
That's the worse case scenario. A lot of work to remove the old clear, polish the metal back bright, and then letter it, then coat with a clear to prevent tarnishing. But, it can be done...
Good luck!
Threads: 54
(04-29-2016, 10:45 PM)gary rabbitt Wrote: (04-27-2016, 05:44 PM)debra Wrote: Also re the band below the buttons, is that copper? I saw the advice about not using Brasso on it....
Thanks!!
~Debra
Good luck!
Gary;
I'm pretty sure that the lettering is embossed in the brass strip in some way, and then filled with paint, if it was not the lettering would have rubbed off on most of them a long time ago.
Thank you for your replies.
That is the correct schematic and pin out diagram for the rectifier. The resistance acro...bluecap — 11:01 AM |
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
There are currently 3959 online users. [Complete List] » 4 Member(s) | 3955 Guest(s)
