Western Auto Radio Restore
Very nice!
Icon_clap Icon_clap Icon_clap
Uses a ballast tube?? I see it has a 68v 300ma heater string.
  Thanks Bob. I appreciate that.
 Terry it doesn't have a ballast tube. It had a BC resistor 17a -30 ohm 3watt & 17b- 106 ohms. 9 watt. I replaced it with two power resistors. First time I used  10 watts for both but they were very hot think I could fry an egg on the chassis. So I went with 2 power resistors that I bolted to the chassis 1-10 watt for the 3 watt & a25 watt for the 9 watt. It helped but still pretty darn hot.
  Here is the schematic. If you want to take a look.
http://www.nostalgiaair.org/pagesbymodel...023640.pdf
Stunning! Awesome!
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4011 online users. [Complete List]
» 2 Member(s) | 4009 Guest(s)
