Philco 71 - chassis washers?
Pulled the chassis and speaker from my Philco 71 and was curious if there were originally rubber washers between the chassis and cabinet. It appears that the two rear monting holes have a larger recess to accomodate a washer perhaps. If this set had them, they are long gone. Thanks!
Good news is - it looks as though this chassis has never been touched. Nothing worse than getting something that has been possibly butchered up in the past Icon_lol
I have not seen the rubber gromments in the Philco 70 and 90 sets. So I am not sure, but I doubt that it had them.
Renovated Radios carries what you need:
http://www.renovatedradios.com/parts.html
Scroll way down to see chassis rubber "washers."
Chuck
