rewire philco90 highboy speaker
what is the best way to re wire a philco90 speaker and a good way to open up the bake lite plug it looks to me the best way is to recon it and dose any have the cloth wire for this sorry about the last post I have been up for over 24 hours working my regular job
ben
Mg.....what exactly do you want to do? Plug or something else?
Some punctuantion and more accurate writing goes a long way when you try to formulate a thought so others coild understand. Icon_smile
Mike
Mike  mike
Look at what you wrote  Icon_confused
Just ask him to rephrase the question
Sam
Hi Ben, I think you are adking about replacing the speaker wires. There was a philco 70 speaker rewire discussion recently that might help.
http://philcoradio.com/phorum/showthread.php?tid=15052
