Imperial Radio
Hello
I was given an Imperial radio. It has no Model ID on it. It has 6 tubes. One 6A7, one 6D6, one 75, two 42's and one 80. It has two tuning knobs, one for AM and one for SW. A knob to switch from AM to SW. A knob for on/off and volume. So I am looking for help in finding a schematic. I am unable to post pictures because my picture files are too large. They are over the 500kb limit.
Thanks Bob
Here's some info on one way to resize photos, there are many image programs you can use to do it.
http://philcoradio.com/phorum/showthread...2#pid35972
 It could be a private label radio made by Belmont, Wells Gardner, or one of the other independents for a store chain. Alternatively it may be a foreign made set, American style tubes were commonly used in many places around the world in the 1930s, 40s, and 50s, such as in Italy, Australia/New Zealand, and even in France. It would be helpful to see some pictures, a chassis layout can tell you a lot about who made a set.
(09-21-2016, 10:00 PM)klondike98 Wrote:  Here's some info on one way to resize photos, there are many image programs you can use to do it.
Thank You Bob
I used Paint it worked great.
Bob
What is on the back?
No metal tag? Maybe a red one or a CX serial number?
Kirk
Chassis is the same as an Imperial 694
The pictures below are a Monarch with the same chassis....
http://www.radiomuseum.org/r/imperial2_694.html
 My guess would be that these "Imperial" radios were either made by Belmont or Sentinel so I would have a look under either of those makes, under the 1935-37 model years.
(09-22-2016, 09:36 PM)OldRestorer Wrote:  What is on the back?
Kirk
Only tag is the Imperial on front of radio. Nothing on the chassis either.
Bob
(09-22-2016, 09:39 PM)OldRestorer Wrote:  Chassis is the same as an Imperial 694
Thanks. It sure looks right. I'll check the Web site out.
(09-23-2016, 03:53 AM)Arran Wrote:   My guess would be that these "Imperial" radios were either made by Belmont or Sentinel so I would have a look under either of those makes, under the 1935-37 model years.
Thanks. I'll do that. I'll post what I find.
Bob
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4856 online users. [Complete List]
» 2 Member(s) | 4854 Guest(s)
