Philco 38-5 veneer issues, what is this wood?
I have done several threads on veneer replacement, one not to long ago on a Philco 650PX. It will show a lot of what you ask, also done a thread on a 1936 Wurlitzer juke box veneer on whole cabinet with rounded sides. Ron could find them in archives and tag them that you can open thread.
Fred, I have a better idea:
You find them and post links.
Icon_smile
You can do a search for your own posts, or search by username "Frederick W. Taylor".
http://philcoradio.com/phorum/search.php
 It's plain cut French walnut I believe. But since some of the veneer is damaged and is scrap anyhow you could use it for gluing experiments.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8491 online users. [Complete List]
» 3 Member(s) | 8488 Guest(s)
