grill cloth
hey guy`s
I have a 40-503. looking for grill cloth.
 has little diamond pattern
 I have not seen any thing like it. any one have suggestion
[Image: http://i1303.photobucket.com/albums/ag14...thiwc0.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...h26txn.jpg]
Kenneth has a pattern called Diamond Reversible that might look OK; its not like what you have but....
second from the right, top row http://richmonddesignsinc.com/grille_cloth_product_page
