Philco 41-260
How hard is it going to be to find a nice dial bezel like this one, without buying the whole radio?  I don't suppose anyone is making new ones?  Not a rare radio, just good sentimental ties....
[Image: http://www.surfacezero.com/g503/data/500...1-260b.jpg]
steve
I would say very hard as no one makes them
and even good ones are hare to find
sam
 Probably the best way to replace one of those that's warped, shrunk, and cracked, is to make a replacement out of wood.  I seem to recall that someone on here did that with a table set that had the same sort of escutcheon. Alternatively one could make one out of sheet plastic stock, such as ABS plastic, by cutting out the pieces and gluing them together. On my 42-327 cabinet, with a similar dial placement, the escutcheon was made out of wood from the factory, and painted black, and it looks very similar to that plastic one.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2712 online users. [Complete List]
» 2 Member(s) | 2710 Guest(s)
