Model 70 Cathedral front panel?
Is there anyone out there reproducing front panels for model 70 cathedrals? Looking into buying one but the front panel is a horribly made homemade one that looks hidious...wanting to know what the price on a reproduction would be so I can make an offer...
Send an email or PM Steve Davis.  He might be able to help you.  See: http://www.philcoradio.com/davis.htm
Steve sells them on eBay regularly. Right now there's none. But I'm sure he'll make one for you.
Awesome!! Thanks very much....
