Threads: 83
City: Annapolis, IL
State, Province, Country: USA
I can see that being a problem with the grounded filament. That is a lot of voltage between the heater and cathode, and a direct B+ short to ground wouldn't be kind to the trans. I didn't see the whole schematic, but if the filament weren't grounded, wouldn't that eliminate the problem? Well, maybe, maybe not ... it could then put that across the HK of the weaker signal tubes, then one of those short, = lots of excitement. ![Icon_eek Icon_eek](https://philcoradio.com/phorum/images/smilies/icon_eek.gif) I have several radios that use this tube, but they all use the GT tube, not the G tube. One did have a bad power transformer - worked ok, but just ran super hot. Gradually got worse til I replaced it. Maybe was related to a failed 6X5 at some point?? ![Icon_eh Icon_eh](https://philcoradio.com/phorum/images/smilies/icon_eh.gif) But, even if one of the silicon diodes shorts, that wouldn't be any too kind to the trans either.
Tim
Threads: 14
City: Irvington, NY
I would just put a fuse in the primary lead of the power transformer and stop worrying about it. This applies either to the 6X5 tube or a replacement silicon rectifier.
Rate the fuse marginally higher than the maximum current draw of the radio under normal operation. If the rectifier should short, it will blow the fuse within a few seconds, protecting the transformer from any sustained overload.
Threads: 54
Kirk;
This is much ado about nothing. The 10-S-464s have 6X5 problems because the engineers over at brand Z decided to ignore the specs in the RCA or Sylvania tube manual that states that the maximum current rating of a 6X5 was 70 ma, and whatever the maximum plate voltages were (they vary based on load and what the input filter is). They thought that they could get around it if they used pairs of 6X5s with the diodes wired in parallel rather then using an #80 or a 5Z3. In something like a five or six tube radio, with a 6K6 output tube, or a wire recorder, or a record player, there was never a problem with using a 6X5/6X5G/6X5GT, but connecting them as they did in a 10 tube radio with push pull 6V6s was just asking for trouble.
Depending on the year or production run, Philco used either type 84s or 6X5s in the power supplies of their 40-180, 41-280, 42-380 series chassis with few problems, the reason being is that they kept the B+ voltage down around 180 volts and used either #41s or 6K6s for power output tubes, which incidentally were designed for car radio use as well.
Threads: 54
(12-23-2016, 11:05 AM)TV MAN Wrote: I can see that being a problem with the grounded filament. That is a lot of voltage between the heater and cathode, and a direct B+ short to ground wouldn't be kind to the trans. I didn't see the whole schematic, but if the filament weren't grounded, wouldn't that eliminate the problem? Well, maybe, maybe not ... it could then put that across the HK of the weaker signal tubes, then one of those short, = lots of excitement. I have several radios that use this tube, but they all use the GT tube, not the G tube. One did have a bad power transformer - worked ok, but just ran super hot. Gradually got worse til I replaced it. Maybe was related to a failed 6X5 at some point?? But, even if one of the silicon diodes shorts, that wouldn't be any too kind to the trans either.
I also have several radios that use a 6X5 rectifier, and not one set that I have encountered with this tube has had a failed power transformer, but I have run into at least two or more sets equiped with a 5Y4 that had a shorted high voltage winding, shorted filter caps or a shorted tone correction cap is all it takes. I also do not trust rectifier diodes, least of all the 1N4007 cheapies many seem to use, I figure it's better to pay the extra $.10 and use at least 3 amp rated diodes connected in series.
Threads: 563
1N4007 is an excellent diode, I used it in many designs without any ill effects and the current that would be demanded in a radio is below its 10% rated capacity.
The reason they are cheap is because they are so good and omnipresent, and mfred in this numbers they nust have to be.
Threads: 54
Kirk;
I should also add that in substituting a tube rectifier with a silicon diode or diodes that the B+ will now be full on before the tube heaters have had a chance to warm up, so in the past in things such as TV sets they used to incorporate a thermistor in line with the high voltage to keep the voltage down for a minute or so. The voltage spike can also hard on the filter caps, with no load the B+ can hit 400 volts or more before the tubes warm up, it's probably less of an issue with modern electrolytic caps but such spikes could cause the old style ones to short out.
Threads: 563
Add to that (for Kirk, he might not be aware of the difference ) - NTC thermistors. There are also PTC ones and they do the opposite.
New member
Hello all. New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM |
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM |
Make sure th eperson who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM |
I would disregard everything that is there now. I do not know who and when changed it.
1. Make sure that what you thi...morzh — 12:36 PM |
Model 27-84 BUZZ?Humm?
Depends on the type of hum. SOme is made by outside devices.
Try installing an X-cap (0.2-0.5uF) across the AC line, ...morzh — 12:23 PM |
Thank you for your replies.
That is the correct schematic and pin out diagram for the rectifier. The resistance acro...bluecap — 11:01 AM |
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
There are currently 2822 online users. [Complete List] » 2 Member(s) | 2820 Guest(s)
