EICO 235 VTVM
Just have some time to repair. I almost gave up could not find the schematic. Once  I did the two main problems zero adj R23 bad. R6 3.3M leaky. I again replaced all carbons. I did not have a 91M so the mass on the upper left is 20M and one 10M. I replaced the cap and diode as well.
Here is the page in the manual that helped
The schematics
Hi, I am looking for some help on the R-23 when I try to do the calibration it says to adjust R-23 to zero the meter but R-23 does nothing. Where did you get with yours?
For those of you following at home here's a copy of the manual:  http://bama.edebris.com/download/eico/23...%20235.pdf
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 4589 online users. [Complete List]
» 2 Member(s) | 4587 Guest(s)
