Philco B572
Does anyone know how to get this apart? Its a Philco B572 Code 121.. After removing screws on bottom it will not come out of the case
Help..
[Image: http://i292.photobucket.com/albums/mm38/...enrkga.jpg]
Duplicate thread here:
http://philcoradio.com/phorum/showthread.php?tid=16111
This one is closed.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2933 online users. [Complete List]
» 2 Member(s) | 2931 Guest(s)
