Help radio philco model 23A
Hello i,m Italian and looking for a schematic diagram of radio philco canadian
model 23A someone can help me? Icon_smile
Thanks to all
Alessandro
Hello Allesandro. You may want to contact Dave at http://www.justradios.com in Canada. He has a extensive collection of schematics. If I had one, would be glad to share, sorry I dont have much on Canadian Model Philcos here. Perhaps others here may be able to help as well. Good luck with your Philco restoration!
Many thank for your help unfortunately justradio.com don't have a schematic but i look on internet i have find a schematic of model 40-165 I think that the same radio in my possession
Thank you all and I would like for your site
When I have finished the restoration will send the photo on the site http://www.radiomuseum.org of which they are associated.
If you want to send to you.
Regards Alessandro
Icon_biggrin
