Philco Model 37-620
Would anyone know what version Philco model 37-620 the attached image is? I do need a schematic for this version.
http://i350.photobucket.com/albums/q430/...fuxrki.jpg
[Image: http://i350.photobucket.com/albums/q430/...fuxrki.jpg]
MHZ-Radio
Jack
jack
pic did not come out
heres how to if needed
http://philcoradio.com/phorum/showthread.php?tid=29
sam
I copied and pasted the link and opened it in a new tab (using win 7). The image came up OK. I used photobucket to save the image from my computer and upload to the Forum. Guess I did something wrong if you can't open the image.
Jack
jack I added pic to your post
I hate using photo bucket any more Icon_thumbdown Icon_thumbdown
sam
Restoring Philco 96
There are currently 7835 online users. [Complete List]
» 2 Member(s) | 7833 Guest(s)
