Model 41-250 frequency shift
Now that I have the electrical restoration of my 41-250 completed, I was aligning the radio per the Philco info and ran into a possible problem. When aligning the antenna trimmer, item 2, on the 9-12Mc shortwave band I notice the radio frequency shifts quite a bit, forcing you to adjust the trimmer and constantly retune the radio. Is this normal with this radio or do I have another problem to investigate? Thanks.
Harv
There are currently 8748 online users. [Complete List]
» 3 Member(s) | 8745 Guest(s)
