philco 47-1230 strange Cap
I am in the process of restoring this model and came across a strange cap in the fm section. it is a .01 mfd cap with 3 leads and i was wondering how do i duplicate this cap. here is a picture of the cap and any help with this would be appreiciated.
[Image: http://i1281.photobucket.com/albums/a508...wuz8go.jpg]
Go to the Philco Tech Section here in the Phorum.
3-Legged Capacitors in Postwar AM-FM Philcos
Icon_smile
Thank you Ron for the quick reply and solution.
Restoring Philco 96
There are currently 7572 online users. [Complete List]
» 2 Member(s) | 7570 Guest(s)
