Audio driver transformer
Just registered. I picked up a Philco shelf xcvr carcass of unknown model and date at a hamfest. It has a serial number tag D 09758.  No power xformer so I'm guessing it's an AC/DC rig.
I'm interested in getting specs for what I think is an audio transformer part number 32-8179N. It has at least one wire left that goes to the voice coil winding of an oval speaker.  Tube complement is 1 XXD, 1 7C6, 1 50L6 GT, 1 35Z5, 4 x 7b7 loctal base tubes.   I got it for a buck as a parts donor, and now I need a low power audio xformer for a breadboard project.
I'm not interested in a restoration so if any of you want parts from it RSVP. I have some remains of the wood cabinet but it's pretty rough.  tnx in advance, chuck
Hi Chuck and welcome,
It would be considered an audio output transformer. Pri 2K @ 40ma Sec 4 ohms.
GLOM
Terry N3GTE
Welcome to the Phorum!
Icon_wave
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7810 online users. [Complete List]
» 3 Member(s) | 7807 Guest(s)
