Model 90 question
Anyone know the value of the volume control on a late model w/avc? Parts list just sez volume control and can't find a cross reference for the part number.
Tnx
(03-29-2017, 10:56 PM)Radioroslyn Wrote:  Anyone know the value of the volume control on a late model w/avc? Parts list just sez volume control and can't find a cross reference for the part number.
Tnx
500K ?
5366 pot is, seems like from the discussions, 500K part.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6212 online users. [Complete List]
» 4 Member(s) | 6208 Guest(s)
AvatarAvatarAvatarAvatar
