Philco model 41-220 schematic question
hello all. This is my first Philco restoration . I have a scheamatic from the Beitman supreme publications for model 41-220, 41-225 Question . I have worked on a Rogers radio and a zenith radio and there schematic seem to have more details such as parts list and alignment information. I hate to order on from the many online providers , As I am not sure if I am going to get the same info. I am sure that various manufactures would include more details than others. I also have read on another Philco site that som sets had changes made in the manufacturing of some sets and the schematics would have been updated... Just want to start on the right foot.
Thanks
Hi Blaine.
Try this link. http://www.nostalgiaair.org/PagesByModel...013395.pdf
This is a little more information than just a Beitman schematic. This is from the Riders manual.
Hope this is what you need.
thank you
There are currently 10362 online users. [Complete List]
» 2 Member(s) | 10360 Guest(s)
