Philco 96 help please
For voltage measure you can use this    http://www.nostalgiaair.org/pagesbymodel...013901.pdf
It will get you in the balllpark. (model 95 diagram)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6561 online users. [Complete List]
» 3 Member(s) | 6558 Guest(s)
