Philco 89 code 123 switch replacement
My model 89 came with a replacement on/off switch and no connection for changing bands. I have obtained a replacement switch and need to know where the band switch connections need to be made. As you can see most of this chassis appears unmolested except for the switch.
[Image: http://i248.photobucket.com/albums/gg187...mowwlf.jpg]
[Image: http://i248.photobucket.com/albums/gg187...8ukjle.jpg]
Jim, here are some photos from my 89 that should help.
Dave Thomas
Coatesville, PA
Thank you Dave, those will be very helpful.
Well, my 89 lives and the alignment went smoothly. Now just need the chassis washers, ordered from renovated radios, and a spring for the dial cord and I will consider the chassis portion done.
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 3419 online users. [Complete List]
» 1 Member(s) | 3418 Guest(s)
