Philco 91 Console, Satin or Gloss?
I have a Philco 91 floor model, that I am refinishing. Did they originally have a glossy finish, or more of a satin finish?  Thanks, in advance.
The original finish was high gloss lacquer.
Thanks, Ron! Pics of completed radio for the gallery, coming soon.
