Do I have a 37-60 or 37-61?
I have a Philco that I restored years ago and I am now working on it again. The cabinet sticker says it is a 37-60, but I think the chassis is a 37-61. How do you tell what chassis it is? I can't find any stickers on the chassis. The chassis tunes broadcast and shortwave 6-18 Mhz. I have a 37-61 schematic, which makes me think I considered it a 37-61 when I bought the schmatic. I have another similar cabinet and I may have mixed them up.
Sounds like a 37-61 chassis. The dash-60 tunes 2.3 to 7.4 on SW. Other than that I think the chassis are essentially the same.
There are currently 10362 online users. [Complete List]
» 2 Member(s) | 10360 Guest(s)
