Crosley Bandbox 601 / What could go wrong??
Worked on the dial and drive last night and got it working, works swell!!
Have a couple of small details to sort then cleaning and paint.
[Image: http://antiqueradios.com/forums/download...?id=187868]
[Image: http://antiqueradios.com/forums/download...?id=187869]
Painted the panel last night and cleaned up the tuning caps this morning. Started reassembly this afternoon. Still have to clean up the other panel components and a touch of paint.
Looking nice!
Greg
So after a long hiatus I got busy on the 601, actually I was getting tired moving it around the work bench and it's three times a big when it's in pieces. I thought I had some pics of it around but can't seem to find them.
Found an online schematic (redrawn) but I think there is a error in the filament wiring. flashvol25_iss2(7).pdf I'll sort it when I power it up. It's all pretty much wired up but needs a good cleaning.
There are currently 10159 online users. [Complete List]
» 2 Member(s) | 10157 Guest(s)
